TwinTurbo.NET: Nissan 300ZX forum - code thirty four is for the knock sensor only. It has
Subject code thirty four is for the knock sensor only. It has
Posted by red TT (STL) on April 23, 2008 at 6:15 PM
  This message has been viewed 130 times.
In Reply To Re: Re: throttle body cleaned now car wont start posted by crabara on April 23, 2008 at 03:51 PM
Message nothing to do with the oxygen sensors. Your knock sensor is bad. You can either replace it, relocate it, or put a 1k ohm (iirc) resistor in the connector to make the code go away. I would replace or relocate it.
